I have a 30X40 shop at my house. Who ever laid the concrete did a **** poor job of it. They laid it in 10X20 sections. The sections are not completely level 1/8 or 1/4 difference. They also used a rough brush to texture the surface. This is great for trapping dust and dirt in! I want to refinish the floor and put down some epoxy paint. If I put more concrete down I will have to put a minimum of 2" down to prevent cracks right? Is there a better alternative?<O</O
About 10 years ago I was working for a company that contracted with grocery stores. We repaired a couple of loading docks with a product that was self-leveling and which was ready for fork lift traffic within 24 hours. Can't remember the name of the product now but I'd guess it's even better now than it was then.You might try checking some material handling sites.
I called a guy I used to work with. He said to look for BONSAL or ENDUROSEAL on line. He doesn't remember the specific product we used but does remember it was suitable for hard tire forklifts.
The epoxy is good stuff. If you just want to get rid of the brush marks, go to a tool rental and get a concrete grinder. Use water with it or it will smoke you out.
The epoxy is less work. Do a google search and you might find the right stuff..
as an alternative option, line your whole floor with mats. Doesn't need to be the checkerboard type...there's solid grey ones out there (Griot's Garage is one site). Though not real cheap, it is probably less work and may be cheaper than more concrete.
The floor may have suffered from slab curl. The top of the slab cures faster than the bottom, causing the top to shrink faster. This curls the slab up at the edges. This is an extremely common problem in warehouses. Forklifts driving over the unsupported curled up edges cause the concrete to crack along the edge. So not only does the owner suffer with the annoyance of a rough floor, the floor deteriorates further in use.
The best way to avoid this is to specify a low water/cement ratio, and keep the placing crew away from the water hose during the pour. If the resulting slump is too low, a mid-range water reducer or super plasticizer can be added to the mixture to make the concrete more workable.
But it is too late for that in your case. If you plan to roll heavy rigs across the uneven edges, even self-leveling grout won't help you. (The slab edges remain unsupported and may break under the weight.)
you may want to look at how industrial folks deal with this problem. One pointer is here:
