Sponsored by: Auxito
Need Help Diagnosing Strange Problem
Old Jan 3, 2006 | 07:32 AM
BigBassJC's Avatar
BigBassJC
We have a 2001 F-150 with the 4.6L V8. Within the past few weeks the truck has been acting funny. Sometimes while driving, the engine will start revving high around 3,000 RPMs, the oil gauge will disengage and the red oil light will come on, the engine temperature gauge will go off and the overdrive light on the column will flash off. The service engine soon light is also on. The truck feels like it drops out of overdrive and is only in about 3rd gear at most. When at stop the engine will rev up and down on its own and when it goes back to idle it is somewhat rough. This episode will last a few minutes then the oil and engine temperature gauges will come back on and the overdrive light will stop flashing. The service engine soon light stays on however. The truck will run fine and this won't happen again until several hundred miles. I would appreciate anyone's help on this. I'd rather not get screwed out of money taking it to the dealership to get it hooked up to the computer to see what is wrong.
Old Jan 3, 2006 | 07:51 AM
92merc's Avatar
92merc
You really need to start by taking the truck to a Autozone or similar place. They usually will pull the Check Engine Light (CEL) codes for you. With all of those symptoms, it could be quite a few things. The codes will start you on the right path. It'll be easier to do it now than later if it totally dies.
Old Jan 3, 2006 | 11:35 AM
86moneypit's Avatar
86moneypit
This may be a long shot but can work sometimes. I would check with the dealer first, and as long as it is safe, try removing the ecu harness, and then putting it back in, it could be a loose harness connection.
Old Jan 3, 2006 | 11:54 AM
gui88ford's Avatar
gui88ford
best place to start is the codes.....autozone or advanced auto will pull the codes.....the way i look at it is why make it harder than it needs to by....let obdII do something for you.....then you have a place to start at
Old Jan 4, 2006 | 08:13 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome BigBassJC, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 4, 2006 | 09:25 AM
l-m tech's Avatar
l-m tech
pull at the wiring harness at the back side of the passenger cylinder head and see if the vehicle acts up.have seen the harness chaff at this spot causing weird problems like this.
VaSheriff
Jun 27, 2023 08:25 PM
Tugly
166
Aug 6, 2015 12:46 PM
Utah Jake
Jun 16, 2015 10:58 AM
Jesser02EX
35
Jul 14, 2014 12:17 PM
rrowley
Jan 4, 2013 08:22 PM
