4r70w broken spring
Old Jan 2, 2006 | 02:44 PM
johnsat's Avatar
johnsat
4r70w broken spring
Will a broken spring on the 1-2 accuator cause the truck not to move in drive? Truck was stuck and being rocked back and forth, went from reverse to drive and acted like it was in neutral. Trans is out, I have the valve body off and all the accuators out the only problem I see is the broken spring, the one between the cap and accuator not the one under the accuator. Thanks
Old Jan 3, 2006 | 06:59 AM
BlueOvalBoy's Avatar
BlueOvalBoy
busted 1-2 accumulator spring on my 70w made it stick in first gear up to about 4000 rpm.
Good luck. Sounds like your issue is elsewhere.
Peace
