Intermittent Miss
Old Jan 2, 2006 | 01:18 PM
92F1504x4351's Avatar
92F1504x4351
Intermittent Miss
Intermittent Miss
I’m new to the list.
I bought new a 1992 F-150 Super Cab 4x4 5.8L with the E4OD and 140,000 miles
Recently, the engine has started running rough and missing/jerking at various speeds.
The engine starts easily; oil consumption rate has not changed since new, gas consumption rate still 11-13 MPG. The battery and alternator are good. The transmission works properly. I changed the MLP/Neutral Safety switch a couple of years ago. The gauge for the front gas tank works intermittently and the ABS light stays on. There are NO Trouble codes present.
Since then I have done the following;
Replaced Timing Chain
Replaced Plugs, wires, coil, cap, rotor and Fender Mounted ICM
Replaced fuel filter
Replaced Thermostat
Replaced PCV Valves
I need some suggestions as to what I should try next.
The local garages are limited to trouble shooting using codes only.
No one has an Engine analyzer in my area.
I’m open to suggestions.
Old Jan 2, 2006 | 03:40 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
