Throttle Problem
Old Jan 2, 2006 | 11:00 AM
jzannier's Avatar
jzannier
Smile Throttle Problem
I beleive the inner shaft spring is broken since there is no longer any return pressure on the gas pedal. The cable is in place on the gas pedal and I can accelerate up and down but no resistance. The tip of the sring is below a fixed part of the throttle body. I see a wipe mark were the sring was riding back and forth. I tried to bring the tip end of the sring back there but it doesn't seem long enough. Is there a replacement part only for this or do I have to get a new throttle body assembly? If so then is it better to get one of these aftermark upgrades which claim up to 30% fuel saving? Is it better to increse the bore or adding the spacer?
Old Jan 2, 2006 | 03:41 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
I would check with the dealer for the spring or hit a junkyard, I don't think a regular parts store will have it.
What year/engine do you have?
