General Automotive Discussion
General ABS question
Old Jan 2, 2006 | 09:46 AM
maflinchbaugh's Avatar
maflinchbaugh
just a simple general question. ok I replaced my abs sensor in my truck. and everything went fine. but here is my question. What exactly is the purpose of RWABS. Rear wheel abs. I understand abs alows for controlled steering while sliding with brakes. but thats all fine and dandy. but how/what exactly does it do if i only have rear abs?
Old Jan 2, 2006 | 10:08 AM
Neb86's Avatar
Neb86
Pickups are relatively light in the rear when they are empty. On moderate to hard braking the rear wheels tend to lock up sooner than the front giving you the potential for a spin. ABS prevents this, or should.
Old Jan 2, 2006 | 10:57 AM
oldgoat49's Avatar
oldgoat49
I had a Dakota that had RWABS and it was the worst POS on slick roads to stop I have ever had. It would seem to me that the two systems would be working against each other. With ABS you don't need to pump brakes, but without it you need to. The B3000 seems to do pretty good although I'm not even sure if it even has ABS.
