Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Help Me Please!!!!
Old Jan 2, 2006 | 04:50 AM
troyboys90's Avatar
troyboys90
Unhappy Help Me Please!!!!
I have a 90 ranger 2.4 lt, 2wd with a man. tranny and it runs like poo. the timing belt is in good shape with good tension the only thing that i found out of the ordinary is cyl compression #1 and #4 have 125psi and #2 and #3 only have 50psi this is my only form of transportation if someone could give me a heads up on this situation i would greatly appreciate it thanks
Old Jan 2, 2006 | 05:06 AM
bterry's Avatar
bterry
Welcome to FTE.
It doesn't sound good for you - no compression is usually not an easy fix. It can only be a few things that cause it: Rings, Head Gasket, Burnt valves, or something like a cracked block or head.
How are your fluids? Any gas smell to the oil? Any backfire up through intake? How many miles on the truck?
Also, maybe a mod can move this thread for you, as there will be better advise in the appropriate forum (4 cyl engines).
Old Jan 2, 2006 | 07:46 AM
gbadgley's Avatar
gbadgley
Blown head gasket between #2 & #3 cyl.
Diesel Submariner
39
Aug 7, 2015 01:11 PM
89f150billy
22
Jan 25, 2014 12:12 PM
Oldyella66
1997 - 2003 F150
13
Aug 24, 2011 01:12 AM
Titus136
Apr 4, 2011 08:02 PM
