High Idle Need Help!!
Old Jan 1, 2006 | 09:53 PM
1988f150xlt3's Avatar
1988f150xlt3
Exclamation High Idle Need Help!!
I have an 88 f150 302 with about 240,000 miles on it. I replaced the tps and iac today. It idles at 2600 rpm and remains there until I put it gear. When in drive, it runs at 1400rpm. Before I replaced the tps and iac, it idled at 2600 rpm and would drop to 1500 rpm after a minute or two. Now it doesn't drop at all. Any ideas on how to fix this before my engine blows? Thanks alot.
Old Jan 1, 2006 | 10:12 PM
yamanx's Avatar
yamanx
Check your intake, and injectors, all that.
Old Jan 2, 2006 | 05:56 AM
WALJON's Avatar
WALJON
SOUNDS like your plenum gasket or 02 senser I had this same problem on my 88 302
Old Jan 2, 2006 | 08:00 AM
1988f150xlt3
How hard is the plenum gasket to change on these trucks. How about the O2 sensor?
Old Jan 2, 2006 | 08:30 AM
EPNCSU2006's Avatar
EPNCSU2006
Have you tried pulling codes from the computer? It might give you another idea of what is wrong. I really doubt that the O2 sensor is causing a high idle like this. I'd suspect a vacuum leak or a sticking throttle. What happens to the idle speed when you unplug the IAC?
Old Jan 2, 2006 | 11:37 PM
1988f150xlt3
When I unplug the IAC the idle lowers. It is brand new though. I am going to clean the throttle body, replace the gasket and replace the plenum gasket. Do you think that will do the trick? When I spray carb cleaner around the plenum gasket the idle lowers.
Old Jan 3, 2006 | 06:51 AM
EPNCSU2006's Avatar
EPNCSU2006
How low does the idle drop to when the IAC is unplugged? If it is still high, it's most likely either the throttle sticking or a vacuum leak. Sounds like it is a vacuum leak since there is a change in idle when you spray the carb cleaner.
Old Jan 3, 2006 | 12:28 PM
andym's Avatar
andym
Definitely a vacuum leak. Don't worry about the injectors. I don't see how they have anything to do with the problem.
Old Jan 3, 2006 | 06:58 PM
WALJON's Avatar
WALJON
Plenum Gasket !!!!!
Old Jan 3, 2006 | 08:07 PM
sjser's Avatar
sjser
$4 Plenum Gasket $4 Plenum Gasket $4 Plenum Gasket
$4 PLENUM GASKET - Order it from your dealer, takes about an hour to replace with 6 bolts (maybe need a long tool for in between plenum stacks). Do it yourself or have the dealer do it in 1 hour. My brother in law's a ford mechanic & did it at his house in under an hour, so take no bull, 1 hour or less by the shop manual. Solved my problem - exactly as you describe.
Wanna check it out? Let your engine cool to ambient. Start her up and with garden hose in hand, spray the engine where it meets the plenum. As the water fills the engine top you'll temporarily plug the vaccum leak and ilde should go down to normal. As the remaining water is sucked into the manifold she'll start to make a loud sucking noise (where the gasket is blown out) and your idle will once again go high - there's your confirmation - git her done
Old Jan 4, 2006 | 05:04 PM
1988f150xlt3
I got a new throttle body gasket and plenum gasket tonight. I am planning on cleaning it all up and putting in the new gaskets. Thanks alot guys.
