degreasing engine
Old Jan 1, 2006 | 07:43 PM
cwt580's Avatar
cwt580
degreasing engine
techniques to degreasing motor and bell housing to clean up and look for oil leaks. What to cover up.... what to spray with......do it at the car wash???? what to be careful with high power sprayer??
Old Jan 1, 2006 | 07:48 PM
PSNut's Avatar
PSNut
Lots of Simple Green applied for 15 minutes with gentle warm rinse. Reapply for second rinse...very effective and safe. High pressure could compromise seals.
Soft toilet scrub brush for big clusters of dirt/grease. This is how i clean with NO adverse reactions.
Hope this helps.
Old Jan 1, 2006 | 08:06 PM
cwt580's Avatar
cwt580
what about altenators.etc.........
Old Jan 1, 2006 | 08:15 PM
PSNut's Avatar
PSNut
Your alternator can handle a fair amount of moisture. Home Depot has cans of electrical cleaner that should degrease housing with out causing problems. I always keep a couple cans of this cleaner around...very handy for a lot of stuff.
Old Jan 2, 2006 | 11:31 PM
99F-250lova's Avatar
99F-250lova
All I did was take mine to the car wash, left it running, and high pressure washed it. It worked just fine.
Old Jan 2, 2006 | 11:35 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
I'VE DONE THAT BEFORE AT THE CAR WASH BUT NOT WITH THE ENGINE RUNNING.
DON'T THINK I'LL DO IT AGAIN THOUGH
Old Jan 3, 2006 | 01:08 AM
cangim's Avatar
cangim
I've heard many great things about using simple green. I have a bottle but haven't used it on the engine yet, it works great on everything else I have used it on so far. The last time I washed the engine i covered the filter and the alternator just cause.
Old Jan 3, 2006 | 05:48 AM
blueeyes2478's Avatar
blueeyes2478
cover the alternaterwith a plastic bag.It you wash your engine and you dont use it for the day,then i wouldnt cover it.But if your going to use it,cover it.When i washed mine and used the truck not long after,my alt was fried.
Old Jan 3, 2006 | 06:34 AM
dunbar15's Avatar
dunbar15
In your diesel manual that came with the truck it says not to wash the motor when hot or damage can occur.. I think it says possible fuel system damage but I'm not sure, check it out, not saying ford knows everything but wanted to make you aware of it. I suggest doing it
with a cold motor..
Old Jan 3, 2006 | 09:24 AM
Medic 66's Avatar
Medic 66
Hope this helps.
Almost the exact way I did it too...and boy it looks good now.
Old Jan 3, 2006 | 09:31 AM
guzzle92's Avatar
guzzle92
Originally Posted by dunbar15
......................I suggest doing it with a cold motor..
The simple green trick really works well but I do it when the engine is warm to the touch, exhaust temp of maybe 180*. This way the simple green seems to do a little bit quicker job plus everything drys a little sooner after the rinse.
Old Jan 3, 2006 | 11:29 AM
dunbar15's Avatar
dunbar15
guzzle92 thanks for the great info, so you wouldnt do it on a hot motor ??
Old Jan 3, 2006 | 12:01 PM
Fat Diesel's Avatar
Fat Diesel
First do the CCV mod if you haven't already. Then use some rags to wipe down the motor dry. Have you ever tried a t shirt on a greasy engine? It works wonders.
Old Jan 3, 2006 | 01:03 PM
guzzle92's Avatar
guzzle92
Hot motor? Absolutely not! Good way to crack something by hitting it with cold water, like an exhaust manifold or block!
Old Jan 3, 2006 | 03:53 PM
qman's Avatar
qman
Did my old 72 with Simple Green last summer and she still smells pretty.
