Wiper Delay Problem
Old Jan 1, 2006 | 04:30 PM
mdm350's Avatar
mdm350
Wiper Delay Problem
I installed a delayed wiper switch and black box into my 86 F-350, both parts are used, but supposedly they work. My high and low setting work as normal. The delay setting will operate only like a low setting and will not change speed as I turn the **** further. Is there a way to test the switch or box? Any ideas or suggestions are appreciated.
Old Jan 1, 2006 | 06:54 PM
mdm350's Avatar
mdm350
I checked it in the evening and now the black box makes a buzzing noise in the interval position. The wipers do not move in any position. I am wondering if the drop in temperature made the difference.
Old Jan 1, 2006 | 09:45 PM
fordborn's Avatar
fordborn
Thread moved to " Electrical Systems/Wiring" forum. Should find more resources here for your question.
Old Jan 2, 2006 | 05:08 AM
tjc transport's Avatar
tjc transport
i ain't rite
did you ground the delay box?? if you did, than it sounds like the delay is bad.
Old Jan 2, 2006 | 09:44 AM
mdm350's Avatar
mdm350
I did ground the switch, which is sufficient enough to turn on a test light. I will probably resoder the connections in the black box to see if that does anything.
Old Jan 2, 2006 | 10:35 AM
tjc transport
i ain't rite
there should also be a ground wire coming out of the delay box. if this wire is not grounded, it will not work properly.
Old Jan 2, 2006 | 11:43 AM
mdm350's Avatar
mdm350
Thanks I will see if I can locate it.
