General Automotive Discussion
problem with '01 grand prix
Old Jan 1, 2006 | 09:50 AM
andy79's Avatar
andy79
The service engine light came on the wifes grand prix. I had Autozone plug their scanner in and said the coolant was taking to long to heat up. I think the code was "128".? They said thermostat or temp. sensor. I replaced the temp. sensor. I started the car to make sure it wasn't leaking. I noticed that both fans came on right away. I know there is a sensor to turn the fans on, but could it be something else? Any ideas? Thanks a lot.
P.S. the car has 50,000 miles on it. 3.1 V-6.
Old Jan 1, 2006 | 01:20 PM
osbornk's Avatar
osbornk
The fans run if the AC is on OR if the windshield defroster is on (it activates the AC).
Old Jan 1, 2006 | 01:29 PM
Zero Obliquity's Avatar
Zero Obliquity
It could also be a stuck thermostat. The PCM 's on the 3.8's will set that code if you have a lower thermostat (185 or 165 instead of 195), or if the thermostat is stuck open.
Old Jan 1, 2006 | 09:01 PM
andy79's Avatar
andy79
I went back to autozone and they cleared the code. We'll wait and see if it comes back on. Thanks for the suggestions!!
slifer
17
Jan 28, 2008 09:44 PM
CaptGuz
North Carolina Chapter
16
Jun 5, 2007 01:13 PM
cdrmotorsports
16
Mar 24, 2007 09:33 PM
sierraben
Aug 2, 2005 08:05 AM
BigF350
28
Jun 27, 2005 07:14 PM
