Hi everyone and Happy New Years I haven't posted before just read most of them and got the information i needed but today i need some help
I have a 1994 Explorer and when i am driving at low speed (35 - 45) the truck dose shake alitte but when i am on the highway when i reach 60 the truck shakes like a mad man hit a bump and it wants to go all over the road. but if i bring it down below 60 (55) it shaks alittle or if i go over 60 shakes alittle but still wants to jump all oveer the place when i hit bumps
I had the tires checked for balances (first thing i thought) there all ok then i checked the front wheel bearings front right alittle losse checked to see if any frontend parts were broke or heavaly worn i couldn't tell
Any help would be great getting tired of shak ratteling and rolling
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
I guess this is a new car for you then. Many explanations for this problem. I found my 2 front shocks werre loose. That cleaned up about 75% of the shake but only after I changed all bushings in the car to polyurethane. Most common issue is radius arm bushings. Check here for a pretty thorough run down on Explorers. http://draco.acs.uci.edu/explorer/
Autozone has a lot of diagrams on the web site if you need a quick reference. My shocks were new too but just came loose over time. Pulled my transmission out last week and the mount was busted so maybe that's part of my vibration. Won't know till I get it back together.
