Tuff Country Lift Install HELP
Greetings Everyone,
I am installing a 4" Tuff Country Lift on my 1988 F150. It has the extended radius arms, which are posing a small problem.
If I install the new radius arm braket (DRIVERS SIDE) where they say to, it sits right on top of the fuel pump bolts. I would have to remove these bolts and drill through the new bracket to allow these fuel pump bolts to go through the new braket plus the frame and back to the fuel pump.
Has anyone else ran into this problem with the same lift\truck? Any help would be greatly appreciated.
Thank You!!!!!
Thank You!!!!!
