Carrier bearing replacement
Old Dec 31, 2005 | 08:00 PM
surfclam's Avatar
surfclam
How involved is it to replace the carrier bearing? I have a slight vibration under power from a standstill that I think is the carrier bearing. Do you have to take the driveshaft apart? I dont know if I want tackle that myself-
Old Jan 1, 2006 | 07:27 AM
empiretc's Avatar
empiretc
Yeah, i had that *****. replace it and be sure to shim it. if you search one really nice gentleman posted a ford tech advisory about shimming. I made my own out of a good piece of steel, cuz if you buy it from the stealership it is a piece of rubber for like $39. You will have to pull the driveline out, while you are there might as well replace the ujoints. That way you can grease them! I went through hell with mine ttrying to get rid of that problem!
