General Automotive Discussion
Bizarre car problem
Old Dec 31, 2005 | 04:21 PM
Caplax40's Avatar
Caplax40
Bizarre car problem
Car is a Nissan Sentra SE-R that I have been working on as a mini-project car. Here is the newest problem:
I had the car up on ramps to clean out the throttle body and got the speedo cable all nice and hooked up. I fired up the car, and it ran beautifully and kept it on till it warmed up to normal running temps.
So I decided to take it for a test drive to make sure that the speedometer worked. I turned off the car, ran and got my jacket and then fired her back up and rolled it off the rampstands. And it just died.
So I thought maybe it was a fuel problem. I hadn't filled it up since before the new engine was installed, so I added two gallons of gas. No go. It cranks, but won't turn over. Fuel pump is working. I don't get it.
Any ideas?
Old Dec 31, 2005 | 04:26 PM
oojbearoo's Avatar
oojbearoo
it seems to me that you car doesnt like your jacket... sorry....jk
are you getting a spark at the wires ?..is your battery reading 12.2 or higher ?
Old Dec 31, 2005 | 04:34 PM
9explorer8's Avatar
9explorer8
How/with what did you "clean out" the throttle body?
Old Dec 31, 2005 | 04:48 PM
tjc transport's Avatar
tjc transport
i ain't rite
did you put everything back together and clamp it down after the TB cleaning?
if the clamps were loose and the intake came loose from the MAF, that would do it. most cars will not run if the MAF is not in line and sensing airflow.
Old Jan 1, 2006 | 07:58 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
Have you checked for spark?
Old Jan 1, 2006 | 12:17 PM
Caplax40's Avatar
Caplax40
Hey guys. Here are the answers to your questions:
-I have spark and fuel is getting to the plugs.
-I cleaned the throttle body with some "STP Throttle Body/Air Intake Cleaner"
-Everything is clamped down nice and tight.
After some troubleshooting yesterday I think the problem lies in the wire that goes from the distributor to the engine. Not sure of the properm term(s). As a friend of mine cranked the engine I fiddled with the wires to make sure they were all seated properly and that wire had some effect on it.
I'm not sure though and am actually kind of doubtful that's it. I'm headed to Autozone in awhile so I'll post the results.
Thank you very much for your help!
Old Jan 1, 2006 | 06:34 PM
9explorer8's Avatar
9explorer8
Might want to pull at least one plug and see what it looks like: Wet, Fouled, etc.
