03 Eddie Bauer Exp
Old Dec 31, 2005 | 02:31 PM
mmpr's Avatar
mmpr
03 Eddie Bauer Exp
I have a serious problem this new years eve day. I went to start our 03 expedition last night and when I turned the key on a buzzing sound started coming from the passenger side fuse box and the engine will not even turn over. I checked the fuses and they are ok. On my dash there is an adv trac off error, along with backup aid. We hooked up an OBD II and when it trys to read it comes back with a link error. We hooked up the OBD II to by brothers excursion and it works fine in his truck. We are stuck 2 hours away from home at the moment. Any Ideas?
Old Dec 31, 2005 | 06:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 31, 2005 | 09:53 PM
ford390gashog's Avatar
ford390gashog
that buzzzzzz is from the fuel pump relay fuse. are you 100% sure that fuse is not blown? it prevents the engine from turning over also.
Old Jan 1, 2006 | 11:51 AM
mmpr's Avatar
mmpr
Thanks, it was the PCM relay fuse. Started right up. Must of missed that fuse.
