Sponsored by: Kumho
Brakes lock up
Old Dec 31, 2005 | 12:14 PM
rmalottwtes30's Avatar
rmalottwtes30
Brakes lock up
Its a 1976 ford f-100 2wd
When you go down the road and you just barelly tap the brakes both back brakes will completelly lock up on me, I have adjusted them both all the way down and it still does it. The truck was converted over to power brakes. The brakes are new, both pads are the same size, is that right cause what came off they were different sizes. Would it be because of not having much of a front brake because it nose dives. Thanks for the help
Old Dec 31, 2005 | 06:21 PM
stuart1's Avatar
stuart1
Unbolt the master cylinder and pull it away from the booster.
You don't need to disconnect the lines.
There is a rod with an adjuster.
Back it off and the brakes will apply easier.
Old Jan 1, 2006 | 09:31 AM
rmalottwtes30
Yea but if you do that wont it make more brake go to the front?
Old Jan 1, 2006 | 10:45 AM
stuart1's Avatar
stuart1
No. The braking will be even.
The front brakes are applied first anyway.
Old Jan 1, 2006 | 02:12 PM
rainbowATF's Avatar
rainbowATF
Rear brake should apply first. Then front next and will do most of braking. If front first it will nose dive; try applying only front brake to a ten speed bicycle for a more dramatic picture of the effect. Did you use a master cylinder and proportionating valve for power brakes in addition to booster?
Check rear shoes and drums for contamination by diff lube or brake fluid. What condition are surfaces of drums? Rust, scoring, excessive wear.
Old Jan 1, 2006 | 02:55 PM
stuart1's Avatar
stuart1
The rear brakes do not apply first.
Old Jan 2, 2006 | 08:21 PM
rainbowATF's Avatar
rainbowATF
Quote from "How Stuff Works":
http://auto.howstuffworks.com/master-brake2.htm
"The metering valve compensates for this, making the drum brakes engage just before the disc brakes. The metering valve does not allow any pressure to the disc brakes until a threshold pressure has been reached. The threshold pressure is low compared to the maximum pressure in the braking system, so the drum brakes just barely engage before the disc brakes kick in.
Having the rear brakes engage before the front brakes provides a lot more stability during braking. Applying the rear brakes first helps keep the car in a straight line, much like the rudder helps a plane fly in straight line."
Discussion follows on proprtionating valve also in article.
I'm sure we disagree on milliseconds, but there are other references and threads here refering to adjustment and operation of rear brakes in relation to front.
Old Jan 3, 2006 | 09:49 AM
stuart1's Avatar
stuart1
Yes but.
Lets look at the inside of a rear brake drum.
When the brake shoes are retracted there is a gap between the shoe and drum.
Whereas a brake pad is in constant contact with the rotor.
Yes we are talking milliseconds.
But the system being full of fluid it stands to reason the front will apply before the rear. Due to the fact it takes just that little bit more time to extend the shoes.
Master cylinders are constructed in such a way the rear portion of the cylinder is applied first, then the front.
The front brakes are applied withy the rear portion of the master cylinder.
Pool time dude. You rack em.
Old Jan 3, 2006 | 02:43 PM
andym's Avatar
andym
On a properly adjusted drum brake, the shoe is in constant contact with the drum. Just like on disc brakes.
Old Jan 3, 2006 | 04:46 PM
stuart1's Avatar
stuart1
I just dragged my from the factory Ford manual out.
Adjust rear brakes until the shoes are in contact with the drum.
Back off adjsuter so the drum turns freely without drag.
To me that does not say the shoe is in constant contact.
Old Jan 3, 2006 | 04:55 PM
andym's Avatar
andym
Interesting. I have always been taught to adjust brakes so that the shoes drag slightly all the way around the drum.
Learn something everyday, I guess.
Old Jan 3, 2006 | 06:22 PM
Hardman's Avatar
Hardman
I had this same problem a couple of weeks ago, went over everything. I could not find any problems.It has been well below freezing, so a friend suggested parking it inside to thaw it out. I left it in for two days, after that my rear lock up went away. I do not know what the root cause was but it was an easy fix. My rear brake lock up was dangerous as the front would not brake until I pushed the brake pedal really hard. I don't know if this will help ? Every thing works now. Good Luck !!
