Sponsored by: Real Truck
tire help
Old Dec 31, 2005 | 09:27 AM
johnnyk's Avatar
johnnyk
tire help
I have a 2004 f-250 crewcab 4x4 and need new tires. I don't want to replace the stock wheels (16x7) but want to go a little taller. 2 questions. (1)..can i go with a 265/75/16 on a 7 " wheel and (2).. this tire is d rated at 3000 lbs and my current tire is e rated at 3042lbs. I pull a fith wheel camper about 5000 miles a yr. camper is about 9000 lbs. will 42 lbs make that much diff. when pulling. any advice would be helpful. Thanks in advance
Old Dec 31, 2005 | 10:46 AM
Autobahn F-250 Lariat's Avatar
A 265 will fit... that is what mine came with from the factory and i would go with an E rated tire
Old Dec 31, 2005 | 10:52 AM
montana869's Avatar
montana869
the tire is going to be a little bit stiffer in an e rating and that is the real benifit your going to get while towing.
Old Dec 31, 2005 | 11:10 AM
EnviroCon's Avatar
EnviroCon
A 265/75R16(31.6x10.4) tire is actually a pinch shorter, but wider, than a 235/85R16(31.7x9.3) tire.
Old Dec 31, 2005 | 11:11 AM
LI250's Avatar
LI250
I replaced my E rated pirellies that came stock with a 285 75 16 D rated tire on the stock aluminum 8 hole rims. The D rated tires will give you a better ride when empty but will bubble out more when towing. This will also cause the tire to "roll" on its side wall a little when in a corner. I tow my Jeep on a commercial flat trailer fine with the D rated but it was better when I had the E's.
wcohalloran
Jul 11, 2014 12:09 PM
RL250
18
May 6, 2014 06:49 AM
Doonz
Sep 6, 2013 09:09 AM
vtmtnguy
All Things Towing
17
May 19, 2009 10:34 PM
