Leaking Master Cylinder on PSD
Old Dec 31, 2005 | 06:11 AM
Varkwso's Avatar
Varkwso
I have a minor leak on my 1999 F-250 4x4 6 SPD PSD master cylnder. I noticed it by the wetness on the frame rail in the driver side wheel well. I cleaned everything up and it is not leaking from the brake lines and it is not losing fluid out of the reservoir at a rapid rate. Braking action seems unaffected. It is still leaking fluid - somewhere.
Not having a lot of experience with diesels I have no idea what the little "blue can" is (pressure accumulator is my guess) on the master cylnder casting is but it may be the source of the leak.
thanks
Old Dec 31, 2005 | 09:12 AM
Kwikkordead's Avatar
Kwikkordead
thanks
What's coming out? Brake fluid or ATF? That will tell you what's leaking. The little pressure accumulator that you speak of is the hydro-boost. They use hydraulic boost instead of vacuum to provide braking assist.
Old Dec 31, 2005 | 09:55 AM
Varkwso's Avatar
Varkwso
Must be brake fluid (looks like it)- how would ATF get there?
Hydro-boost it is dripping off it.
Old Dec 31, 2005 | 10:00 AM
Kwikkordead
The power steering uses ATF as the fluid. They hydroboost is driven by pressure provided by the power steering pump. That's why I was asking about what's leaking. Whatever fluid is coming out will tell you what's leaking and needs to be replaced.
Old Dec 31, 2005 | 08:44 PM
Varkwso's Avatar
Varkwso
Thanks - now I understand - I will check the power steering pump level...
Old Jan 1, 2006 | 07:12 AM
empiretc's Avatar
empiretc
Wow, master cylinder. Be sure that is it. Might be the line coming from the power steering. I like the fact that on our trucks the power steering pump also runs the brake booster.
Old Jan 1, 2006 | 07:14 AM
empiretc's Avatar
empiretc
FYI, if you need the replacement, stay away from autozone and oreillys. If you dont want to spend the bucks to get it from the dealer, get it from NAPA. Just telling you from past experience
Old Jan 1, 2006 | 07:27 AM
Varkwso's Avatar
Varkwso
Thanks - I have had good luck with rockauto.com in the past. I have also used some online Ford dealers in SC to get jobber rates. It looks like an expensive piece to replace....
I will be checking all the connections from the power steering pump now.
Old Jan 1, 2006 | 07:29 AM
empiretc's Avatar
empiretc
IT is, but think of it this way. It has been done, you are not gonna have to worry about it!!
I hate my truck for the money I have had to spend on her, but IT IS DONE!!SHe purrs like a kitten now,,,,
Old Jan 1, 2006 | 03:20 PM
Varkwso's Avatar
Varkwso
Power steering was down about an ounce. Cannot see any leakage around the hydro-boost, brake lines, power steering pressure line or return line. I can detect minor seepage around the master cylinder near the firewall and that is about it...
Minor leaks, vibrations and electrical can drive you nuts....
