1978 - 1996 Big Bronco
Windows fogged
Old Dec 30, 2005 | 05:08 PM
1970Custom's Avatar
1970Custom
Windows fogged
I'm having troubles with my Bronco fogging up on the inside, but the outside is bone dry. and its not just a little moisture, just wiping the inside of the windshield can soak a dish towel.
What can I do to stop this? Put a heater in it for a while so it dries out?
Help,
Old Dec 30, 2005 | 05:18 PM
Streetgang's Avatar
Streetgang
To cure the problem you need to find out where all the moisture inside your truck is coming from........make sure you dont have a leak where rain water is getting in.
As for the moisture thats in there already......well I am not sure if there is some sort of appliance that will aid in the removal, or if you just need to let time dry it all up.
Old Dec 30, 2005 | 07:26 PM
timack's Avatar
timack
Heater core leaking? Do you smell antifreeze?
Old Dec 30, 2005 | 08:32 PM
1970Custom's Avatar
1970Custom
No, actually I don't (I would know too, the one in my '70 was great at it) and the floor isn't wet either.
I asked my dad tonight and he said its possibly from the wet weather we're having and that I only drive it once a week usually.
Old Dec 30, 2005 | 11:33 PM
jem270's Avatar
jem270
A rainX type of product should help you. I use one made for the inside since my air conditioner does not work. It really helps with condensation.
Old Dec 31, 2005 | 01:58 AM
Kings Liaison's Avatar
Kings Liaison
A lack of a vapor barrier between the door panel and door frame can cause this if the belt weatherstrips are leaking badly. you should probably check this first.
