1978 - 1996 Big Bronco
Engine swap, 1991 into 1986
Old Dec 30, 2005 | 09:35 AM
SVTguy's Avatar
SVTguy
Exclamation Engine swap, 1991 into 1986
Hi guys,
I blew up the 351 in my 86 but I have a 1991 with a 351 with a shot body.
I was wondering if I can swap the intake manifold and carb onto my 91 long block and have it work? I searched and found that it can be done between 302's so I assume it can work with 351's also.
I was also wondering what else I would have to swap (timing cover, fuel pump, etc.)?
Any help is greatly appreciated.
Thanks, Phil
Old Dec 30, 2005 | 11:08 AM
Kemicalburns's Avatar
Kemicalburns
yes it will work. you will need to swap over the timing cover, fuel pump and water pump as well. since your in that far it would be a good idea to replace the timing chain as well. and maybe install a new water pump. good piece of mind ya know.
have fun
Old Dec 30, 2005 | 12:18 PM
SVTguy's Avatar
SVTguy
Yeah, you are right. Just hope I can start it before it snows again. Thanks for the help.
todd512
Jun 25, 2014 10:58 PM
Freddie Murphy
Nov 25, 2012 09:15 AM
ian_ak
Mar 22, 2012 08:52 PM
medino03
Jan 21, 2012 04:01 PM
Lothurin
May 4, 2006 09:28 AM
