No Compression
Old Dec 29, 2005 | 07:22 PM
bkuykendall's Avatar
bkuykendall
Question No Compression
Have a 1994 Ranger XL, 2.3L engine, many, many miles. From the beginning: My Ranger has almost always ran really good up until 4 months ago, always started at the first turn of the key, regular tune-ups, oil changes, etc. Then all of a sudden the timing belt broke (one reason is old belt - I had just replaced the serpentine belt and was working on getting others done). From what I can gather this Ranger has a non-interference engine so when the belt broke it shouldn't have bent any valves. I had my mechanic put on new timing belt, but the truck gets NO compression upon attemps to start it. ??? My mechanic is a good one, but not used to working on Fords. Help, I am hitching rides.
Old Dec 29, 2005 | 08:21 PM
wtroger's Avatar
wtroger
Sounds like belt is on wrong. I have replaced dozens of these and have never had one bend a valve.
Old Dec 29, 2005 | 10:45 PM
budman-mo's Avatar
budman-mo
I agree, not timed right.
I have a 94 but don't remember for sure but I did a 98 (2.5) a couple weeks back and it has several marks, only some work right.
Old Dec 30, 2005 | 04:45 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Old Dec 31, 2005 | 10:41 AM
Bart99GT's Avatar
Bart99GT
Its probably a couple of teeth off and the intake valves are probably still open when the compression stroke starts. Each tooth equals about 18 degrees of crankshaft rotation.
I think it is pretty common knowledge that the camshaft sprocket timing pointer on 2.3L engines is woefully inaccurate. A neat trick to set the cam timing is to take a piece of string and run it between the center of the auxillary shaft and camshaft bolts. Scribe a mark or fabircate a new pointer that lines up with the string and then set the cam timing to that mark or pointer.
Old Dec 31, 2005 | 10:57 AM
agryphon's Avatar
agryphon
I probably should do this soon - Is it possible to just mark the position of each sprocket before removing, then match them up when re-installing? Or is there more to it then that?
Old Dec 31, 2005 | 11:22 AM
budman-mo's Avatar
budman-mo
Here is all the info (if you haven't looked).
https://www.ford-trucks.com/lc/lc.ph...TimingBelt.doc
Old Jan 4, 2006 | 11:03 PM
bkuykendall
Red face Thanks
Thanks for the info. I have already gone to autozone.com. I did, however, print the one you sent me. I appreciate your time.
Betty K.
bbacon
Sep 27, 2014 02:40 PM
tiopet
Apr 2, 2013 01:20 PM
onsiteford
Mar 23, 2012 10:48 PM
PHOTOG101
Sep 30, 2009 05:21 PM
docs89gta
21
Oct 9, 2005 06:34 PM
