ac only blows on High now..
Old Dec 29, 2005 | 01:43 PM
HTRDLNCN's Avatar
HTRDLNCN
All the other speeds stopped working.
I wouldnt mind in the middle of summer
but in our "so called" winter it gets a bit much.
Am I looking for a fuse or a relay and where?
Thanks!!!!!!!
__________________________________________________
WWW.HOTRODLINCOLN.ORG
"Dog Hair Racing"
2004 GTO ,Almost stock,3790lbs , 1.7 60FT / 12.8@106
1996 F250 Powestroke,3" dp,no cat,5"tip,46637 filter,not quite as fast
1972 Oldsmobile 442 , under construction
Old Dec 29, 2005 | 01:46 PM
ford390gashog's Avatar
ford390gashog
you need to find the resistor.
Old Dec 29, 2005 | 03:12 PM
HTRDLNCN's Avatar
HTRDLNCN
Ok,,where would that be?
Old Dec 29, 2005 | 04:11 PM
Bob Ayers's Avatar
Bob Ayers
They are usually mounted into the heater box on the firewall. The correct term for this resistor is the blower resistor assembly.
Old Dec 29, 2005 | 09:36 PM
HTRDLNCN's Avatar
HTRDLNCN
Thank You!
"Dog Hair Racing"
1996 F250 Powestroke,3" dp,no cat,5"tip,46637 filter,16.9@83.3
