Gas tanks
Old Dec 29, 2005 | 09:49 AM
skymonkey's Avatar
skymonkey
Gas tanks
what do you guys think about a gas tank behind the rear axel? I have the rivets out of the last crossmember so i can get more room for the gas tank. I have found that a 1970 mustang/cougar should fit. Reason for this type of tank is that i want to run the filler out to the back of the roll pan. Any suggestion.
Old Dec 29, 2005 | 11:31 AM
Fomoko1's Avatar
Fomoko1
Excellent idea, gives some room behind the seat with fuel supply out of the cab. The later Mustang tanks, about 71/72 hold alittle more fuel than the 70 I believe. You may have to change the neck angle to have the filler come through the roll pan.
Old Dec 29, 2005 | 12:11 PM
skymonkey's Avatar
skymonkey
Do you think that would be the best tank for that idea? I found out that the 70 is a 22 gallon tank were as the earlier tanks a 18-20 gallon tank. the only problem i think i would run into is the tank straps. would the 70 model tank straps work as well?
Old Dec 29, 2005 | 12:20 PM
4Cammer72's Avatar
4Cammer72
try searching for this. its come up a bunch and theres some who have done the swap.
Old Dec 29, 2005 | 03:08 PM
FLgargoyle's Avatar
FLgargoyle
I had a 28 gallon aluminum tank made for my '70, which I put behind the axle. It worked out well, except for I never was happy with the filler set-up. It also adds a little weight where it's often needed in an empty truck. There is a thread here somewhere about the Mustang tank, which would be a lot cheaper than having one made. I welded up the filler hole in the cab; you can't tell it was ever there.
Old Dec 29, 2005 | 04:40 PM
skymonkey's Avatar
skymonkey
hey thanks guy i think that article really helped me out.
