backfire problem
Old Dec 28, 2005 | 10:16 PM
Ronald E's Avatar
Ronald E
backfire problem
I have a 1983 Ranger 2.0L with a backfire on decel and shifting gears. Other people have said to replace the "gulp" valve. Did that , no luck. all vac lines appear in good order. also replaced the air diverter valve, still no luck getting rid of the backfire. Any help will be greatly appreciated. Thanks
Old Dec 28, 2005 | 10:49 PM
devilsword's Avatar
devilsword
okay the 2.0 is a inline 4 right? well things to check that can cause backfire. Sparkplugs(for cracks and wear), timming, bad wires, Carb needs adjustment, cracked cap or worn rotor, valves sticking, and crossed wires. so check all these starting with the easy ones and work your way through. Good luck. Also check the 2.0 forum they can probly be alot mor ehelp for your engine problems.
Old Dec 29, 2005 | 04:26 AM
tude's Avatar
tude
if you still cant find an answer pull the valve cover off and check the cam/lifters all should be snug-to-tight mine had a valve stick and i just replaced the head
if any are loose than that is the problem, or at least a problem
Old Dec 29, 2005 | 07:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
