is there a website that tells you what the codes are on my 93 bronco's VIN. If not does anybody just have any idea. Here it is.
thanks
VIN
1FMEU15HOPLA34524
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FM
Assembly Country: USA
Make: FORD
Body Style: SPORT UTILITY
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: E
Brake System: HYDRAULIC
GVWR Class: Class E:
GVWR Range: 6,001 - 7,000 POUNDS
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: U15
Vehicle Line: BRONCO
Series: CUSTOM
Chassis Type: 4
Engine Type - 8th Position
VIN Code: H
Engine: 5.8 LITERS
Cylinders: 8
Fuel: GASOLINE
Horsepower: 200 HORSEPOWER
Model Year - 10th Position
VIN Code: P
Model Year: 1993
Assembly Plant - 11th Position
VIN Code: L
Assembly Plant: MICHIGAN TRUCK: WAYNE, MI
Production Sequence Number - 12th - 17th
VIN Code: A34524
Prod Sequence Number A34524
