problems with 86 f150 starting
Old Dec 28, 2005 | 08:40 PM
jimroos's Avatar
jimroos
Hello,
My name is jim and i'm a new member, and i need some help. I have an 86 F-150 2WD pickup that just clicks when you try to start it. I replaced both connectors on battery cables, checked all connections, replaced starter solenoid, removed starter and took to Autozone to have tested and it tested out good, put starter back in and it still just clicks when trying to start. Can someone please help? I would greatly appreciate it.
Old Dec 28, 2005 | 09:21 PM
ford390gashog's Avatar
ford390gashog
Hello welcome to FTE!
Please do not post truck tech questions in this forum!
This forum is for announcing your "arrival", or that you have purchased a new truck/suv, or have posted new pictures in your gallery, or some personal event, etc.
Please take the time to read the headings and notices in each forum. The FTE board is HUGE! We want users to be able to find answers to their questions so it is organized into many areas and search tools are provided.
Please take the time to look around the various forums available. While you are looking around you may find out all kinds of interesting things!
Old Dec 28, 2005 | 11:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Dec 29, 2005 | 02:26 PM
Jrog86's Avatar
Jrog86
Off the top of my head, I would start with the easiest. How's your battery? Are you gettting around 12Volts with the Voltmeter?
Did this problem just start out of the blue? Or was it after you had done something with the truck?
Old Dec 29, 2005 | 02:54 PM
Bdox's Avatar
Bdox
Clean your battery cable connections. Both ends and both surfaces both cables. Make sure that your battery is fully charged. Also insure that you have good clean connections on the ground between the engine and the chassis. Then try it again.
Old Dec 30, 2005 | 06:02 PM
mnmzimmer5's Avatar
mnmzimmer5
My bet...battery or ignition switch
Old Jan 14, 2006 | 06:40 PM
pcelf's Avatar
pcelf
My guess would also be the battery. He did mention checking the posts and the connectors, but didn't mention anything about the water level or whether it had a good charge or not. if those are goood then I woul dcheck the switch. Another thing would be to check the cable between the starter and the solenoid. Just my two cents but they both might be bad pennies, LOL
