Sponsored by: Innova
Help- how to replace speakers
Old Dec 28, 2005 | 07:02 PM
bcoover's Avatar
bcoover
Hello all, my speakers are blown out in my 1991 F150 Lariat. What size speakers do I need as replacements? I went to Best Buy and they gave us 2 seperate boxes of speakers, 4 speakers total. My truck is a regular cab and only has 2 speakers, why would they give us 4? I dont understand, they looked up the exact model and year in their database and it said that it needs 4 speakers.
More importantly, does anybody have detailed instructions of how to remove the speakers on my truck?
Thanks all, ANY help is appreciated.
Old Dec 28, 2005 | 08:38 PM
2000silverbullet's Avatar
2000silverbullet
I can't help with the detailed instructions on the install but maybe with the speaker quantity. Are you sure you only have 2 speakers? I ask because you might have 2 more speakers mounted up on the rear pillars, that's how my reg cab truck was when I had it. Maybe they aren't hooked up or maybe the fader on the deck is set to front only. I'd check that before returning the other pair of speakers.
I'm not sure if www.the12volt.com has any install instructions but you might try that site. You have to register in order to get into the diagrams and stuff but they won't spam you. In fact, I've never received anything from them since I registered over a year ago.
Old Dec 29, 2005 | 12:30 AM
Monty06's Avatar
Monty06
depending on the month of the year your truck was made it can have either 2 or 4 speakers.
Old Dec 29, 2005 | 12:38 AM
ford390gashog's Avatar
ford390gashog
speakers are easy. pull the door panel off , 4 screws hold each speaker in , pull it unhook the leads , then do reverse of that.
Old Dec 29, 2005 | 01:33 PM
hhott71's Avatar
hhott71
beastbuy are tards as are all big box stores.
You have 6.5" speakers in the doors
Pick a pair that sound good to you with the bass/treble etc in the center positions.
Old Dec 29, 2005 | 01:57 PM
ford390gashog
they will only sounds as good as the head unit. if its the stock head unit then i would just get cheap speakers.
Old Dec 29, 2005 | 06:26 PM
bcoover's Avatar
bcoover
It only has 2 speakers. Still working on getting the panel off.
Old Dec 30, 2005 | 03:14 PM
deltasoft's Avatar
deltasoft
i would get some good 300w pioneers or higher with tweeters on them :-) i got mines from walmart for 40 buckz in total cheaper than bestbuy because they dont know how much spkrs are really worth heheheh i was lucky and funny thing is i did the installation right at walmart's parkin lot ......all in one shot....
4x484150
Aug 2, 2016 08:34 AM
6t6merc
Dec 2, 2013 08:01 PM
AMB_F-150
Dec 29, 2012 09:06 AM
del_allen1957
Dec 30, 2007 01:36 PM
MarchOfMephisto
Jan 28, 2006 02:17 PM
