Anitfreeze boiling threw cap??
Old Jan 3, 2006 | 08:53 PM
superf350's Avatar
superf350
Just because it blows coolant out the cap DOES NOT MEAN IT HAS A BLOWN HEADGASKET! How hard is that to understand. The coolant flash boils because of the egr, take the coolant to a minimum or get an SCT and turn the EGR off! It's not rocket science folks!
Old Jan 3, 2006 | 09:10 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Don't be quite so arrogant if you can't get the story correct.
Yes, coolant puking can be caused by either the EGR cooler OR the head gaskets, but if it is the EGR cooler, unplugging the EGR will have absolutely no effect on the problem- only blocking exhaust flow into the cooler or replacing the cooler will remedy the problem. The cooler (and corresponding hot exhaust pressure) is before the valve- disabling the valve does nothing.
Statistically, about 75% of the coolant problems I have seen ARE head gaskets: however, just because they are leaking under load does not mean they are blown; they require replacement eventually nonetheless.
Old Jan 3, 2006 | 09:55 PM
superf350's Avatar
superf350
I'm pretty sure the SCT can close the egr. I will have to find out for sure. NBTW I said have it turned off not unplug. Big difference!
Old Jan 3, 2006 | 09:59 PM
SpartanDieselTech
Former Vendor
No, there is not. Turning it off in the tuning (which yes, it can), and unplugging the valve both accomplish the same task- preventing the valve from opening. This has absolutely no effect on the EGR cooler or any corresponding coolant leaks resultant from it.
Old Jan 3, 2006 | 10:10 PM
superf350's Avatar
superf350
Think about this for a second if the egr is closed so what if coolant is going through it. There is no hot gasses going through the egr because it's closed. I think we are talking about two different things. I'm talking about flash boiling because of the hot gasses passing through the egr causing the coolant going through the egr cooler to boil. If there is no longer any hot gasses passing through the egr then there should be no more flash boiling.
Old Jan 3, 2006 | 10:15 PM
SpartanDieselTech
Former Vendor
It will flash boil with the valve open or closed. The rear of the EGR cooler is plumbed directly into the passenger side uppipe, with no restrictions. The valve blocks it from the manifold at the other end. Exhaust heat and pressure will enter the cooler from the rear no matter the valve position- as EGT's rise, the temperature of the exhaust gasses in the cooler will be behind only by seconds- actual exhaust flow through the cooler has negligable effect on the temperature of the coolant inside the cooler at a given EGT level- if exhaust temperature rises hot enough to start boiling the coolant in the tube, it will boil no matter what, unless the rear of the cooler and/or uppipe is cut and welded to totally block flow into the cooler- the valve is the exit, not the entrance.
See this diagram for reference.
I compose my own SCT calibrations, and I keep the valve shut via the desired EGR position and feedforward tables in ANY calibration I write- yet I still managed to melt down two coolers before eventually cutting and welding the uppipe to remedy the issue.
Old Jan 3, 2006 | 10:35 PM
superf350's Avatar
superf350
You are absolutely right now my question would be that with it shut the airflow would not actually go through the cooler? Granted you'd still have hot exhaust gasses in that general area but it wouldn't flow through.
Old Jan 3, 2006 | 10:39 PM
SpartanDieselTech
Former Vendor
There would be little "flow" in terms of fluid motion of exhaust, but the heat transfer will still be there...and almost as rapid as if there was flow. The heat is what ends up causing boilover from the tube and burnthrough and/or pinholes in the radiator material of the cooler tube.
Keep in mind that dynamic heat transfer through pressurized, extremely heated exhaust gas is ridiculously rapid, especially when there is no solid barrier to act as a heat sink and at least partially absorb fluctuations in temperature.
Old Jan 4, 2006 | 12:32 AM
King of the Road 04's Avatar
King of the Road 04
What if I changed to that non-water based coolant? i cant find the website or the name of it (even though i saved it to my favorites, i say its because PSU won orange bowel and im still up at 130 haha) but would this watwerless coolant help? i understand it boils at a higher temp? justa question............i dont like covering up problems (such as a bad EGR or EGR cooler or headgaskets)
Old Jan 18, 2007 | 09:05 PM
wpgf250's Avatar
wpgf250
Dug this up doing some searching. If I had an egr coller issue, lets say slight coolant leak internally, but mostly puking. Would blocking the exhaust and disabling the egr valve be enough to cure the issues (lets say head gaskets are fine) or would the cooler have to be replaced/bypassed to repair the coolant leak as well?
