Bleeding ABS Brakes
Old Dec 28, 2005 | 11:56 AM
wiseguy's Avatar
wiseguy
Bleeding ABS Brakes
I want to bleed the brakes on my wife's 98 Explorer, but was wondering if I'll run into any problems because of the ABS. I've read that on some models you need an ABS code reader to reset the ABS after bleeding the brakes. Does anybody know the right way to bleed them? Thanks.
Old Dec 28, 2005 | 01:30 PM
oojbearoo's Avatar
oojbearoo
i recently did my 96 xlt and didnt have ne light come on if that helps at all
Old Dec 29, 2005 | 12:21 AM
Monty06's Avatar
Monty06
in order here goes rear right,front right,rear left,front left
if you do the front you also have to bleed the rear vice versa.
Old Dec 29, 2005 | 05:35 AM
wiseguy's Avatar
wiseguy
I'll bleed them normally and see if the light comes on. Hopefully that feature is only on the newer models and I can replace the fluid without having any problems. I hate ABS. It adds so much complexity to a very simple system. Thanks, guys.
Old Dec 30, 2005 | 04:09 AM
allan1010's Avatar
allan1010
According to my Haynes you only need the ABS bleeding gizmo on the pre- 96 models.
Bleeding without the gizmo leaves the pedal soft & spongy like it still has air trapped.
Old Dec 30, 2005 | 05:38 AM
wiseguy's Avatar
wiseguy
Thanks Allan. The one manual I had taken out of the library didn't even mention ABS when bleeding the brakes. Fortunately my wife's is a 98, so it looks like there shouldn't be any problems.
Old Dec 30, 2005 | 05:57 AM
allan1010's Avatar
allan1010
No problem, that was just FYI because you mentioned needing something to re-set the system. AFAIK it isn't a code reader but rather some kind of one-way valve or gizmo that you attach to an outlet on the side of the master cylinder. Mine's a '97 and didn't need it. Yours should be fine.
Old Dec 30, 2005 | 07:26 PM
Jebadiah04's Avatar
Jebadiah04
good way to reset codes is to unhook the battery for a while...jsut a thought
Old Jan 29, 2006 | 04:09 PM
joebogey's Avatar
joebogey
My wife's truck is a '97 XLT with ABS. The only time you need the special ABS gizmo is if you run the master dry and get air in the system. With the way it's plumbed normal bleading won't get the trapped air out of the ABS valving that's below the master. So as long as you blead the brakes nomral and keep the master full of fluid you're fine.
Dutter 2
19
Sep 26, 2014 10:13 AM
Headviking
Jul 31, 2011 12:27 PM
teamlx88
13
Apr 7, 2010 05:14 PM
tboss619
Dec 28, 2008 09:22 AM
jc47
Oct 21, 2007 11:53 AM
