Thread in rocker studs
Old Dec 28, 2005 | 11:16 AM
mcne's Avatar
mcne
What is involved when replacing the stock press in rocker studs with thread in studs? I understand the stock studs are removed, then there is some machining done (I'm not sure exactly what is done). After the threads are tapped into the head the new studs are installed. After that I don't understand if extra hardware is required? Are the rockers now adjustable? Any special I need to know?
