Computer Chips & Tuners
Wideband question
Old Dec 28, 2005 | 09:25 AM
SR_Crewchief's Avatar
SR_Crewchief
Wideband question
I've seen several references to Wideband O2 sensors. Most of the time it looks like the advice is to add on with a display/gauge added. Other times it appears that the suggestion is to replace the basic with wideband so the computer gets a more descreet a/f ratio signal.
The question is, if your replacing the narrow with wide don't you need some sort of signal interpreter between the sensor and the computer? My searchs so far have not been productive, if know of a good info source I'd appreciate it.
Old Dec 28, 2005 | 12:19 PM
MotorHaven Guy's Avatar
MotorHaven Guy
Don't touch the factory sensors.
What you do is get a wide-band sensor and attach it to a data-logging device. Some even come with their own PC or other data logging devices.
If you are actively tuning yourself this is a great way to test your changes to see how "on the mark" the air/fuel ratios are. Use the wide-band datalogging to get an accurate picture of what's going on, nail the tune to where it needs to be, and then let the factory O2's do their job. If you just need to check out the ratios for someone else tuning it, you might be better money-wise to take it to a shop with a dyno and pay for a couple of runs with their wide-band.
What are you looking to accomplish? What's your budget? Do you plan to tune yourself with something like the Tweecer or SCT Pro Racer package? Or do you plan to have us, or a local shop tune it? Let me know and I can make specific recommendations, my answer so far is very generalized.
Old Dec 28, 2005 | 10:20 PM
SR_Crewchief
Thanks, that make more sense. Thanks.
Eventually a conversion from SD/MFI to MAF/SFI on 4.9. The more radical side of me wants to turbo charge and push the 300hp range. The pratical side wants to take bottom end issues that have been creeping up (low oil pressure, appearent blowby, etc) and moderately improve things while getting an mpg gain.
Mostly just doing the research for now.
cbakker
13
Apr 6, 2014 10:42 AM
danlee
Exhaust Systems
Apr 17, 2013 03:18 PM
RIKIL
May 21, 2012 10:10 PM
93_flareside
Aug 27, 2010 04:36 PM
lew52
Jan 23, 2009 04:32 AM
