carb help etc.
Old Dec 27, 2005 | 09:05 PM
bloodhound51's Avatar
bloodhound51
carb help etc.
i have a motorcraft 2100 on a 360 it is fouling plugs when it idles. how do i lean out the mix. i know you use the two screws in the front but i need to know what the stock setting is so i can work from there im not even in the ballpark right now.
Old Dec 27, 2005 | 10:25 PM
Mil1ion's Avatar
Mil1ion
Screw them in to just lightly snug (DON'T go reaf on them)
Back them both out 3 turns.
That's your starting point
Are you using a vacuum gauge to watch for smoothest running while you adjust them ?
Old Dec 27, 2005 | 10:34 PM
plowpusher's Avatar
plowpusher
look down your carb is it pulling fuel over at an idle if it is check float level it could be saturated with gas and starting to sink or the needle and seat could be bad letting gas leak in to your carb causing a rich condition or your choke may not be opening fully
Old Dec 28, 2005 | 09:26 AM
1975Ford's Avatar
1975Ford
Before adjusting fuel / air mixture screws, check for any vacuum leaks, replace any vacuum lines which are cracked, and rubber is stiff.
Then, With the engine off, turn the fuel / air mixture screws in untill the screws bottom out, do not overtighten. then back out each screw three full turns. Then with the engine run, Caution witht the cooling fan. Turn in each of the fuel / air mixture screws, 1/4 turn in (clockwise). the engine idle will smooth out when the mixture screws are closing in on the correct mixture. The mixture screws should be adjusted equally, as to eliminate one mixture screw not being further in than the other screw.
Old Dec 28, 2005 | 04:12 PM
bloodhound51
ok no i am not using a vacuum gauge i am sort of ignorant of carbs so all info is new i can take one apart and get it back together but never can get them adjusted right i will start by snugging the screws then turning both out three turns then i will post again to tell results oh and the truck is smoking white at startup and when you rev it it shakes pretty bad is this do to the plugs fouling or is their a head gasket problem that i need to address.
Old Dec 28, 2005 | 08:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to carb forum.
Check with your engine forum for engine diagnosis.
