Need help wiring a tach
Old Dec 27, 2005 | 02:54 PM
xTritonV10x's Avatar
xTritonV10x
I just purchased my first truck, a 1990 F350 CC, and it did not come with a tach originally. I need som help installing one, I already hooked up the lighting and ground wires but I am having trouble with the green wire that connects to the negative on the ignition coil and the red wire that connects to a switched 12V source on fuse box. Any advice would be helpful, and I'm not the best with this stuff so please be detailed. Thanks.
<!-- / message --><!-- no sigs except when logged in --><!-- controls -->
Old Dec 27, 2005 | 02:55 PM
xTritonV10x
Old Dec 27, 2005 | 03:42 PM
pfogle's Avatar
pfogle
The green wire will hook to the coil where the condensor/noise reducer is hooked in. Just splice it into the wire. In teh fuse box you should have a few connectors labeled "IGN" those are hot when the key is in the "run" position. Use one of them for the red wire. If you have an aftermarket radio you could also splice the red wire from the tach into the red wire on the radio.
Old Dec 27, 2005 | 03:44 PM
ford390gashog's Avatar
ford390gashog
the coil is labled -/+ hook it up to the negative side it may even say tach test on it
Old Dec 27, 2005 | 04:09 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
barnbridge
Nov 11, 2007 09:49 AM
75F350
Offroad & 4x4
27
Aug 30, 2007 07:41 PM
dinikin
Jul 29, 2007 06:06 PM
gier-head
Exhaust Systems
Mar 7, 2006 07:51 PM
Jamouneau
Feb 8, 2006 07:04 AM
