Thin Walls?
Old Dec 27, 2005 | 01:59 PM
thematkave's Avatar
thematkave
Thin Walls?
so is there a way to tell if my 7.3 has those thin walled cylinders I've been hearing about??
Old Dec 27, 2005 | 04:33 PM
Chevy_Eater's Avatar
Chevy_Eater
I could be wrong, but I thought all the 7.3 IDIs had the thin(er) walls. The result of boring out a 6.9.
Old Dec 27, 2005 | 04:37 PM
ford390gashog's Avatar
ford390gashog
all 7.3's have thin walls, they are an overbored 6.9. this is why it is very important to maintain the cooling system and prevent cavitation.
Old Dec 27, 2005 | 06:33 PM
shorthair's Avatar
shorthair
i think what your concerned about is a condition called cavation which is a pitting of the outside cylinder walls in the coolant passagescaused by air bubbles in the coolantsticking to the wall & bursting as the piston passes & vibrates the wall which erodes a small part of the iron block each time IF the coolant has not been treated with an additive to prevent the condition.
Old Dec 27, 2005 | 06:39 PM
Chevy_Eater
Not to scare anyone off, it's still a very good engine. Just needs to be tended to a bit more than the 6.9.
Old Dec 28, 2005 | 02:14 AM
thematkave's Avatar
thematkave
cool...thanks for all the good info!! I never got good help from the chevy forum(when I was a chevy guy...before I upgraded)
what is that treatment called?
and where could a guy get some....
Old Dec 28, 2005 | 02:15 AM
ford390gashog
you need SCA's coolant additves. or convert over to the new ford gold coolant.
Old Dec 28, 2005 | 05:43 AM
trike1946's Avatar
trike1946
You can buy the additive right from Ford. I think it is only about $7 a bottle. Cheap insurance. Also get the test kit so you know how much to add.
Old Dec 28, 2005 | 02:23 PM
thematkave's Avatar
thematkave
cool....... thanks guys
Old Dec 28, 2005 | 03:30 PM
shorthair's Avatar
shorthair
dont know what the price is but these trucks seem to run & run & run with just a little maintence. 2 years ago i gave $2700 for mine & everything but the dome lite works.
