Sponsored by: Real Truck
narrowed it down, need some advise.
Old Dec 27, 2005 | 10:25 AM
nasdaqsam's Avatar
nasdaqsam
Originally Posted by slc10844
I think they list for about $60.00 and discount for about $43.00. If you decide to diy, the electrical connector has a tab on the underside you press to release the connector. Easy to swap out and only takes a few minutes.
Sounds like a diy project. It doesn't sound like it could be much else. Maybe fuel filter.
Thanks for the help.
Old Dec 27, 2005 | 10:52 AM
Gun-Driver's Avatar
Gun-Driver
vibration
My '01 F-150 with the 5.4 did that to me. I was on the way home when it felt like the tranny was slipping or not shifting properly. You could feel the vibration in the steering wheel, but it would only do it under power and you could really tell when it shifted into O/D. I nursed it home than took it to the dealer (still under warranty) two of the COPs went bad. They replaced them and it ran smooth as silk. <O</O
At about 88,000 it happened again but not as severe. As long as you backed off the gas a little it was smooth as soon as you gave it a lot of gas or went up a hill when you needed the power the vibration would start again. It ended up that just one had gone bad this time. Replaced it and it was fine again.<O</O
Old Dec 27, 2005 | 10:55 AM
nasdaqsam's Avatar
nasdaqsam
That describes what this one is doing pretty much. I'll have to pick a couple up and swap them around until it runs better.
Thanks
Old Dec 27, 2005 | 12:50 PM
nasdaqsam's Avatar
nasdaqsam
Is this what I am looking for? http://cgi.ebay.com/ebaymotors/ws/eB...tem=7998903783
The seller claims they are OEM. For $ 250 it's almost worth just changing all of them. Yes/No?
Old Dec 27, 2005 | 06:35 PM
nasdaqsam's Avatar
nasdaqsam
Originally Posted by nasdaqsam
Is this what I am looking for? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ru=http%3A%2F%2Fsearch.ebay .com%3A80%2F%2Fsearch%2Fsearch.dll%3Ffrom%3DR40%26 satitle%3D7998903783%26fvi%3D1&item=7998903783
Anybody? Good deal or not? Thanks
Old Dec 27, 2005 | 07:19 PM
T- Squared's Avatar
T- Squared
For what it's worth, our local dealership charged me $80.00 to run a diagnosis for the same problem you're having. They hooked up a tester and took the truck for a test drive. The test identified the bad COP. Went to NAPA and they had them in stock for $69.00. That's a great price for 10 of them, but chances are you'll never need them all...knock on wood!!!
Old Dec 27, 2005 | 07:27 PM
nasdaqsam's Avatar
nasdaqsam
I agree that would be the wisest way to go but I'm not real happy with the local dealership after the last repair so I will not be going back. I would prefer to spend the extra $100 than have to go back or have to play with swapping them out a couple at a time. However, I just do not know if the ones this guy is selling are OEM. He says they are but.......I wish I could be sure before I lay out the money.
Thanks for the reply
kdawg249
Jan 27, 2011 08:41 AM
MikeMcCasland
Aug 12, 2009 12:58 AM
wolfmanagh
Aug 31, 2006 09:16 PM
79Spitfire
Feb 16, 2005 03:08 PM
