Blinking lights
Old Dec 27, 2005 | 12:54 AM
lilman320's Avatar
lilman320
Question Blinking lights
I have a question, I have a '79 F-250 and for some reason the lights will shut off and turn back on whenever they feel like it after the truck warms up but fine when cold, it's not more than a couple seconds but not driveable on road as is....please help!!!
Old Dec 27, 2005 | 08:09 AM
76supercab2's Avatar
76supercab2
If you are referring to the headlights, it sounds as if the circuit breaker on the switch is cutting out. Common failure for the light switch. Best fix is to replace the switch.
After you replace the switch, go to the tech section and check out the brighter brights article. That modification will reduce the amount of current running through the switch and may prevent a future occurrence.
Old Dec 27, 2005 | 09:57 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
could be the headlight switch, or the dimmer switch....if it happens again try clicking the highbeam switch and see if it changes, if so the replace it....
Old Dec 31, 2005 | 01:27 PM
brownfoot's Avatar
brownfoot
I replaced the headlight switch which helped, but found the problem was the dimmer on the floor, it had a hole corroded in the die cast case, it got dirty and damp and caused the headlight c/b to trip..............replaced it and did the "brighter whites" conversion.................big difference and not too much cost
2004f250superduty
Nov 4, 2013 11:40 AM
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
blackford97
Sep 5, 2011 10:28 PM
LARIAT 85
22
Oct 24, 2009 09:14 PM
redwitch
Sep 3, 2002 09:06 AM
