Brakes Change Time
Old Dec 26, 2005 | 11:27 PM
ZUGtastic!!!'s Avatar
ZUGtastic!!!
Brakes Change Time
So tell me what am I in for? Where's the jack points on front & rear? Will I be able to use a floor jack due to Expy height?
Old Dec 26, 2005 | 11:42 PM
ford390gashog's Avatar
ford390gashog
jack points are in the owners manual. is this your first brake job? if so the expy is a little more difficult to do.
Old Dec 26, 2005 | 11:48 PM
ZUGtastic!!!
first brake job the Expy, I've changed them time many times on my cars. So far Mopars have been the easiest.
Old Dec 26, 2005 | 11:52 PM
ford390gashog
are you doing rotors also? the expy uses torx bolts so you will need torx sockets. i believe it is t45 size
Old Dec 27, 2005 | 12:02 AM
ZUGtastic!!!
im hoping I dont have to, I went to get a flat tire patched the other day and they told me the brakes were almost metal to metal, Now Im hearing a slight rubbing when applying the brakes,(never heard it before they told me) I plan on doing them this weekend to avoid any damage to them.
Old Dec 27, 2005 | 12:59 AM
ford390gashog
if the pads are that worn rotors are almost 100% needed.
