Brake light
Old Nov 11, 2001 | 09:51 AM
fyrfytr's Avatar
fyrfytr
Brake light
Hey guys, I have a little brake light problem. It seems that when I have the lights on and step on the brake the the tail lights go out and the brake light does not work either. I have checked the bulb and also the ground wire. Does anyone have any other ideas? This is only on the passenger side. Drivers side works normal.
Thanks,
Terry
Old Nov 11, 2001 | 12:11 PM
Franklin2's Avatar
Franklin2
Brake light
Couple of things to check:
Is the bulb going in correctly-I've seen where the bulb pins are not engageing properly in the slots in the socket making the bulb incorrectly oriented in the socket.
If you have a voltmeter, check for 12v on the wires. Make sure you put the negative of the meter on the tang in the socket to read the voltage. This will verify you do have a good ground. This reminds me also, that ground tang can get pushed back in the socket and not make good connection.
Old Nov 30, 2001 | 08:40 PM
7220driver's Avatar
7220driver
Brake light
HAD THE SAME PROBLEM AND HAVE SEEN MANY FORDS WITH THE SAME THING, ALL I DID WAS CLEAN UP THE GROUND WIRE AND IT FIXED IT, SOUNDS WEIRD BUT IT WORKED
Old Nov 30, 2001 | 09:06 PM
Mil1ion's Avatar
Mil1ion
Brake light
Please post in Lower case.
Trying to read ALL CAPS is really hard on the eyes and is usually considered *Yelling*
Thank you.
Dennis
I'm the guy with all of the GIFS and I'm not afraid of using them !
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Nov 30, 2001 | 11:40 PM
Mil1ion's Avatar
Mil1ion
Brake light
