Aerostar Ford Aerostar
Fast Idle question`
Old Dec 26, 2005 | 09:19 AM
C Holmes's Avatar
C Holmes
Fast Idle question`
I have a 92 AWD with a 4.0 litre engine and the problem is every once and awhile the van will idle faster than usual. It will do this when the engine is at normal operating temp. Sometimes stalls when cold. I have also noticed a decrease in fuel milage. This is not a daily driver and does sit for extended periods. Could this be O2 sensor or cold start sensor? Where else should I look?
Thanks
Old Dec 26, 2005 | 05:22 PM
copper_90680's Avatar
copper_90680
Clean the Idle Air Control Valve first.
Old Dec 26, 2005 | 05:50 PM
C Holmes's Avatar
C Holmes
where would I find that?
Old Dec 26, 2005 | 06:21 PM
copper_90680
For the 4.0L, it's right on top of the throttle body near the front of the engine, it's cylindrical with a 2-pin connector and is held by two bolts, you can't miss it. Remove it, clean it with throttle body cleaner, and also clean the passages with some small wire brushes.
It might be best, after removal, to separate the valve from the solenoid before cleaning.
Old Dec 27, 2005 | 04:37 AM
Pablo-UA's Avatar
Pablo-UA
Use common carburator cleaner spray and compressed air...
Old Dec 27, 2005 | 12:15 PM
Bear River's Avatar
Bear River
Former ******
No, do not use carb cleaner. Use only Throttle Body cleaner.
Old Dec 27, 2005 | 03:50 PM
Cannon45's Avatar
Cannon45
Fast Idle
Check the vacuum lines on the manifold. Its located on the driver's side of the engine compartment toward the firewall. I had a hose off and my '92 4.0 idled at about 2500 RPM.
Old Dec 27, 2005 | 04:03 PM
C Holmes's Avatar
C Holmes
I will look
Old Dec 28, 2005 | 01:55 AM
Pablo-UA's Avatar
Pablo-UA
If the vaccum lines are not ok, you can hear a "ssssssszzzssss" sound, check lines under the IPC cover too.
Old Dec 28, 2005 | 07:31 AM
C Holmes's Avatar
C Holmes
What is IPC cover?
Old Dec 28, 2005 | 07:55 AM
Pablo-UA's Avatar
Pablo-UA
Instrumental Panel Cluster.
There is a plastic cover, under this cover there are vacuum heater control lines (right hand).
Old Dec 29, 2005 | 01:05 AM
Pablo-UA's Avatar
Pablo-UA
By the way there are a vaccuum lines to Cruise-Controll and to tranny. May be there is a reason to check them too
Old Dec 29, 2005 | 02:20 AM
Monty06's Avatar
Monty06
no one has mentioned the first step . first step is to pull codes.
then go from there .
Old Dec 29, 2005 | 04:35 PM
Bear River's Avatar
Bear River
Former ******
Good point, and in addition to that, the computer has a limited ability to diagnose its own IAC valve. So if there is a bad enough problem with it, then you could get a code for that. The chances of the computer detecting IAC problems is pretty slim, but it can sometimes.
Old Dec 30, 2005 | 05:54 AM
Pablo-UA's Avatar
Pablo-UA
As I remember, Aero '92 is OBDI. OBD-II lets you to see engine data, idle air flow (MAF) and IAC flow. Thats why we have to use mere primitive ways to find a sourse of the problem. I used to remove idle control solenoid (valve was leaved on thoutle body) and look at the result. It is possible to push the valve, and motor speeds up. But do not disconnect harnes from solenoid, or CE may appeare...
