Hey guy's i'm wanting to order a turbo back exhaust for my reg. cab F350 srw but every ad i see say's exc. 137 in. wheel base. if i order it will i have to cut the pipe to fit or do they make systems for reg cabs? i was looking to get mbrp preferably. please let me know reg. cab guy's. thanks for any help!
Call them before you do an online order. I have the MagnaFlow on my reg cab and it fit perfect. One cut to length pipe should be no probem to fit your wheel base.
We havebeen selling the MBRP systems for reg cabs since way back, they calim it won't fit but you just have to cut the MAX amounts from the pipe and it'll bolt right on.
It fits even easier if you cut the factory cat pipe off some, or the cat test pipe if you buy that from us as well. Call us Tuesday and we'll be glad to make sure you have all the specs to know what will work for you.
thanks for the reply's! i figured i would have to cut the pipe between the cat and muffler for it to fit. just wanted to see if i had the right idea or not.
