Sponsored by: Real Truck
Adding keyless entry
Old Dec 24, 2005 | 08:38 PM
kurthb's Avatar
kurthb
Can you add factory keyless entry in a 06 F250 that doesn't have the security option? Or do you need at least the keyfob option?
Old Dec 24, 2005 | 09:41 PM
Smokeless's Avatar
Smokeless
Priced it out at the dealer couple days ago and it is far cheaper to get a remote starter with keyless entry or an alarm with Keyless
Old Dec 25, 2005 | 08:33 AM
dmp437's Avatar
dmp437
I would also just add the Ford Silver or Gold system to the truck rather than trying to "retro" something that was not ordered on the truck originally. You can also pick these sytems up on E-Bay for quite a bit less than the delaer and get instructions and programming info at www.gemsen.com/ford
Old Dec 25, 2005 | 09:28 AM
kurthb's Avatar
kurthb
I was looking at the aftermarket alarms systems, and have to agree that that may be the easier route, although I really would have liked the keyless entry.
Thanks!
Old Dec 25, 2005 | 10:55 AM
dmp437's Avatar
dmp437
The Ford Silver and Gold systems come with Keyless Entry as part of the package. The Silver System is Keyless with a Remote Start function added for those cold mornings when it needs to be warmed up.
Old Jan 2, 2006 | 07:56 PM
les1cam's Avatar
les1cam
Keyless Entry
I have a 2000 Superduty that I bought used 3 years ago. The dealer told me that I couldn't add keyless entry. I had a Bulldog key fob keyless entry installed by a local radio installer and it has worked flawlessly for me these past 3 years. Good Luck!
Old Jan 2, 2006 | 08:38 PM
Streetcruzer's Avatar
Streetcruzer
Here is a >>>LINK<<<< to the pad I believe you are asking about! It pretty much answers your questions.
Hope this helps,
Old Jan 3, 2006 | 02:27 AM
rwilimo's Avatar
rwilimo
Streetcruzer, from the original post, it sound's like he does not have the factory key fobs, so that add on keypad will not work.
Old Jan 5, 2006 | 12:42 PM
Streetcruzer
Thats why I posted the link,so that everyone could read and get their questions answered from the distributer concerning the Ford add on keypad!
Old Jan 5, 2006 | 01:42 PM
kurthb's Avatar
kurthb
Picked up a Code-Alarm alarm that has the key fobs, just in process of wiring up the relays as the module alone can't drive the lock/unlock solenoids.
Old Jan 5, 2006 | 02:56 PM
rwilimo's Avatar
rwilimo
You should just be able to tap the lock wires at the security module without relays. I believe pink/green & pink/yellow
Old Jan 5, 2006 | 07:41 PM
06F2504x4's Avatar
06F2504x4
My wife has a 2000 Explorer without keyless entry. I did some research and found out that most late model Fords are compatible with keyless entry, all you need is a factory fob (Ebay, cheap). To find out if yours is set up, put the key in the ignition and turn it to the on position (not start) and back 8 times quickly. If your door locks cycle, you're good to go. To program a fob, do the same thing with the igintion, but when the locks cycle, press the lock button on the remote, done.
My 2 cents
Old Jan 5, 2006 | 07:52 PM
Streetcruzer
My 2 cents
Thats pretty good info. How would you program the locks not to lock when putting the car in gear, does anybody know??
Old Jan 5, 2006 | 07:58 PM
06F2504x4's Avatar
06F2504x4
www.gemson.com/ford has a document titled Fall Asleep Door Lock Tip
2006 Ford. That explains how to disable autolock and more
Old Jan 6, 2006 | 07:01 AM
kurthb's Avatar
kurthb
Keyless entry installed.
The module only sinks 120mA, not enough to drive the solenoids, that is the reason why a relay is needed.
Works great, but will try the 8X key trick to see if it will accept factory keyfobs. I would think if that were true, that Ford wouldn't have specified that the keyless pad for the door will only work if the vehicle came with factory keyfobs, plus the wiring is different. Plus, if I had the factory keyfobs, I would have not needed the relays. Maybe the SuperDutys are setup different than Explorer's.
