Starter wont disengage
Old 12-24-2005, 01:09 PM
wideopen23's Avatar
wideopen23
wideopen23 is offline
The red wire that runs from the key switch to the starter soleniod is hot all the time when the key is in the on position. Thus not letting the starter disenage when starting. I have by passed the nuetral safety switch but with no luck there. traced wires all look good, this is driving me nuts please help.
Thanks
JC
Old 12-24-2005, 01:24 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
yes it should be on. you might have the 2 wires on the wwrong posts.
Old 12-24-2005, 02:23 PM
ivanribic's Avatar
ivanribic
ivanribic is offline
This is incorrect. The red wire should only have power when the ignition is in the start position and should lose power as soon as the key is released. Maybe someone in here will know for sure but I'd think either the ignition switch has issues and you may have to replace it or there's a short somewhere else along the line. On my ignition switch there are 2 red wires coming out of it, from the same lead, one to the solenoid and I'm not sure where the other one goes. Maybe someone will have an idea on where this wire goes and if it could be shorted out.
Otherwise, this is something that could be "fixed" with a $2 temp push button, and wire your starter through it.
Old 12-24-2005, 02:39 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
SwOkcOffRoader is offline
when my 76 F-150 did exactly the same thing, and the ignition switch was the culprit.....
Old 12-24-2005, 05:55 PM
wideopen23's Avatar
wideopen23
I figured it out, I had two wires on the ignition box mixed up, the red wires is actually red wire...it goes from the switch to the neutral safety swtich then back up to the solinoid. Glad I knowj this now......thanks for the help guys and
MERRY CHRISTMAS
Old 12-24-2005, 06:58 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
As a long time member may I suggest :
To Please add the year of truck when asking questions.
I can only assume you are talking about the 79 because I looked in your profile.
It makes things a lot easier and you can get the PROPER answer a lot faster
BIGT94z
02-01-2012 02:17 PM
Comanche1Star
05-28-2011 08:49 AM
JRC71
Electrical Systems/Wiring
07-29-2008 01:17 PM
judyms772
01-22-2006 11:39 PM
redwood
07-09-2004 12:59 AM
Quick Reply: Starter wont disengage
