Will Not Start
Old Dec 23, 2005 | 08:27 PM
pegasus58's Avatar
pegasus58
Will Not Start
I have an E-350 PSD and it will not start. At first it acted like bad batteries. When I had it towed home. The tow guy thought it could be the starter. I put in a new starter and still will not start. It goes threw the warm up session then just a click. Could it be the relay? I jump it off my big big truck. Were do I find the relay on E- van
Old Dec 24, 2005 | 12:22 PM
Heavy460's Avatar
Heavy460
Mine are located passenger side under hood left of battery under a plastic houseing on the fender.When i went to look for them they were all the way down in the fender,and yes they were bad.The fuel pump relay and the voltage relay.What year?
Old Dec 24, 2005 | 06:49 PM
pegasus58's Avatar
pegasus58
I have 99. It is an old airport shuttle with 90,000 miles. I t works grate as a prim mover for my camper
Old Dec 24, 2005 | 08:26 PM
trike1946's Avatar
trike1946
Have you tried to plug it in for a few hours before trying to start? Have you tested the batteries? Are the connections good on the batteries and grounds? Do you have good fuel presure? How about the cam position sensor? Did you check for any codes? Is it all of a sudden or has it gotten worse over time?
Old Dec 25, 2005 | 10:33 AM
pegasus58's Avatar
pegasus58
No I have not tested the batteries. I did try to jump start it when the tow truck picked it up. I have no code. All I get is one click when I try to start it. It will not turn over.
