Bronco II Ford Bronco II
fuel consumption = bad sender?
Old Dec 23, 2005 | 04:22 PM
bronocIInoob's Avatar
bronocIInoob
it seems i have the sam problem as ive heard other i little wile agi i posted that i had horrible gas consuption it seems as though it went from fulll to about 1/4 with little movement and running in my YARD i dont even drive the thing yet do to the fact that i dont have i licence yet and only ran it to move it or hear somthing i needed to fix i put about 1-1/2 to 2 gallons in and that brought it up to about half from 1/4 now im sure i dont have an 8 gallon tank in there could this be the sender unit or the gauge it self or both ive heard of a mistake of putting a ranger sender in and getting bad readings im going to contact the previuous owner to see if he ever replaced it
Old Dec 24, 2005 | 07:22 PM
Ken00's Avatar
Ken00
I would measure the resistance of the sender while you add fuel, it should be a smooth change.
Old Dec 28, 2005 | 11:19 PM
Monty06's Avatar
Monty06
your not nuts you don't have a 8gallon tank.
you have a 23 gallon tank.
Old Dec 30, 2005 | 09:40 PM
Desert Dog's Avatar
Desert Dog
The senders have a history of going bad this issue comes up pretty regular on most forums,you will have to drop the tank to pull it and replace it but would be a lot cheaper than having a shop do it.
