i just bought a new 06 f250 6.0L when i am going down the road with the cruise set it sounds like the turbo kicks in and out pretty frequently is it supposed to do this?
Look at your Tachometer when you here it doing this. chances are that the truck is just revving a little for small inclines, which would cause the turbo to spool up a bit. Also if it is cold where you are, the Exaust back pressure valve may be comming on to aid in keeping the engine warm.
