carb adjustment
Old Dec 23, 2005 | 09:03 AM
bloodhound51's Avatar
bloodhound51
carb adjustment
i have a 2100 two barrel the motor is running rich it is fouling plugs how do i adjust
Old Dec 23, 2005 | 10:24 AM
derherr65's Avatar
derherr65
Need more info. Was there a time when it worked right? Did it start this suddenly? Is it rich at idle, cruise, power, all? Gasoline fouling is unusual, though not impossible, but could it be oil? Is it engine temperature or air temperature related?
Old Dec 24, 2005 | 11:29 AM
LxMan1's Avatar
LxMan1
Sounds like the float may be sticking due to crud in the needle and seat or the power valve is possibly blown.
Old Dec 24, 2005 | 01:09 PM
fmc400's Avatar
fmc400
MSEE
He probably means carbon fouling. Try backing out the idle mixture screws (under the front of the carb) out a half-turn. Maybe it's just time for a carb rebuild?
Old Dec 25, 2005 | 01:07 AM
LxMan1's Avatar
LxMan1
Backing them out would only richen the idle mixture even more.
Old Dec 25, 2005 | 01:17 AM
ford390gashog's Avatar
ford390gashog
backing them out richens it. you need to turn them in all the way then back them out 3.5 turns each. a rebuild kit is 13.00 i would do that.
Old Dec 25, 2005 | 02:54 AM
fmc400's Avatar
fmc400
MSEE
Not really sure what I was thinking. LxMan1 is right; turning then in is the direction I was thinking of. Been one of those weeks...
