94 F-350 Trans Problems
Old Dec 22, 2005 | 10:34 PM
big green's Avatar
big green
I have a 94 f-350 turbo diesel . i have a rebuilt e-40d trans that always runs hot even with new trans cooler.
It also has very poor performance ,and o/d lite flashes right before the tranny starts to slip. when it finally shifts from 1/2 it feels like being rear-ended.
I think it is probably something electrical because i have tried about eveything else. I also tried by passing the stock trans cooler but the heat problem continued.
I don't know much about electrical, so I would appreciate any ideas thrown my way.
Thanks,
Big Green F-350
Email: chromeconstruction@sbcglobal.net
Old Dec 22, 2005 | 11:16 PM
handyman43358's Avatar
handyman43358
Welcome to FTE. How are you sure that its running hot? Do you have a gauge? I'd pull the codes because your o/d light flashing indicates that your tranny is storing a problem code in the computer. Go to www.fordfuelinjection.com and it will tell you how to pull the codes yourself. Im guessing something electronic. It can be anything from a bad VSS, PSOM, or even a sensor on the injection pump (cant remember exactly what it is.)
Old Dec 23, 2005 | 09:25 PM
Popa Tim's Avatar
Popa Tim
Yes, pull the codes. Its in limp home mode.. .
