*help!!*
Old Dec 22, 2005 | 06:11 PM
Bowcop's Avatar
Bowcop
*help!!*
I need to know, is there anyplace that sells an adapter to tow a 5th wheel from the bumper position? I have an opertunity at a smokin deal on a 20' 5th wheel, but I can't install the 5th wheel hitch, I have to have the bed space to haul my quad. Is there a way for this to be done??
Thanks!!
Tim
Old Dec 22, 2005 | 06:12 PM
The SnoMan's Avatar
The SnoMan
Thanks!!
Tim
They make tow dollies with 5th wheel hitches on them.
Old Dec 22, 2005 | 06:19 PM
Bowcop's Avatar
Bowcop
Where can I find these on line? I did a google and came up with nothing.
Thanks!
Old Dec 22, 2005 | 07:13 PM
The SnoMan's Avatar
The SnoMan
Thanks!
Good question, I know I have seen them. I will have to think on this one and see if I can find a source unless someone else comes up with it first.
Old Dec 22, 2005 | 07:40 PM
tfalk's Avatar
tfalk
Don't know anything about them, but I remember seeing this site...
http://www.hitch-buddy.com/5thwheel.htm
Old Dec 23, 2005 | 12:35 AM
1991fseries's Avatar
1991fseries
doesn't look like anything i'd trust though
Old Dec 23, 2005 | 04:58 AM
The SnoMan's Avatar
The SnoMan
What is not to trust? FedEx, UPS and ABF pull tags all the time. The concept is sound.
Old Dec 23, 2005 | 06:45 AM
CmprSpecial's Avatar
CmprSpecial
Saw one of these at an RV show once. They are pretty sturdy looking, but you have to consider the weight of the dolly in your tow figures, it's pretty heavy...
Old Dec 23, 2005 | 01:44 PM
The SnoMan's Avatar
The SnoMan
It is not the weight factor that some give it. Your engine and axle ratio will determine your true usable GCVW and towing abilty moreso than a "door sticker". Also for those that freak out about exceeding GVW's, the dolly takes the pin load off off of TV.
Old Dec 23, 2005 | 02:42 PM
CmprSpecial
I won't put my dog in that fight, I was only saying the hitch buddy is heavy (1000 lbs according to their specs) and needs to be considered when determining what trailer to buy.
Old Dec 23, 2005 | 03:50 PM
The SnoMan's Avatar
The SnoMan
No arguement there but you should be considering your Trucks "true" towing abilty more when picking a trailer, not whether you are using a dolly per say.
Old Dec 23, 2005 | 05:59 PM
aurgathor's Avatar
aurgathor
Not exactly. If you hook up a 5th wheel with a proper adapter, it weighs down quite a bit on the rear axle, so you get more traction at the rear wheel. If you use the hitch buddy, you won't get much exstra weight on the rear wheell. This less of an issue with big SUVs like an Excursion, especially id equipped with 4x4, but with 2WD trucks, it can be significant. Probably not enough to make much of a difference on good, dry roads, but going uphill on a wet or snowy road can be problematic.
Old Dec 25, 2005 | 12:34 PM
chrono4's Avatar
chrono4
id trust it, you see semis runnin similar setups all the time.
Old Dec 25, 2005 | 12:36 PM
F2504x4's Avatar
F2504x4
Wow is all I can say, that is something I would never try to use.
all the reasons above already mention and consider you are adding another pivot point when backing up.
Be care with this setup, you might look into a over the cab rack for the quad, and stick with the normal fithwheel set-up
check this site for info on what you are trying to do, just be safe & be informed.
http://www.rv.net/forum/index.cfm/fu...g/16104491.cfm
check out this pic.
http://rockymountainatv.org/pages/ph...t-Side_jpg.jpg
Ive seen this before only it did not extend over the bed and the guy was towing a fifth wheel with the quad on the cab.
Old Dec 25, 2005 | 12:48 PM
F2504x4's Avatar
F2504x4
here something for the boaters as well, pretty cool setup.
http://www.eideboatloader.com/boatloader/5thwheel.htm
