I have a question....I saw somewhere a code scanner for a laptop with software and cables for 350.00 or so...does anyone have this? how well does it work? who is the mfgr.? Thanks in advance for any help....mike
my buddy has one like that the only thing the laptop does is decode the code and give you possible ways of fixing the problem ... i got one for 150.00 that came with a book that tells you the codes meaning then if i dont know how to fix it i come on here and ask
$350 is getting up into EEC Tuner or Tweecer range. It better be able to do more than read codes for that much money!
There is a product called AutoTap that sells for $200 that reads codes and also gives you a real-time display of what the engine sensors see. However it only works with OBD-II vehicles.
If you don't require the data logging and real-time capability, I would suggest sticking with a simple hand-held scanner and get the factory Engine/Emission Diagnosis manual for your vehicle.
Go to www.ITPDiesel.com and look at the AutoEnginuity. It is a little device that plugs into your OBD II port under the dash on vehicles made from 1997 and up. I got the extended Ford package that allows me to monitor a bunch of stuff on my PowerStroke Diesel. I can data log high pressure oil, mass fuel demanded, oil temps, pretty much anything that has a sensor. You can then open up the data file and graph the results in Excel. Here's an example:
